Open Drawing from model in Assembly Tree
Right click on model in ASSEMBLY TREE and open drawing option from pull-down menu
21 Comments
GregOlson
It would be a nice feature to be able to open a drawing with right click functionality.  It could be a very simple addition, adding the part or assembly number to the open window UI and adding a .drw behind it.
bduncan
GregOlson
We are currently on WF5....so it's nice to see in Creo 2.0 they have it added.
bduncan
A plug-in for PRO E which called EMX
GregOlson
When you say plug in...do you mean like AAX or surfacing (extension) or it this a separate company that makes a plug in for Pro-e that adds the open drawing function?
DHLewis
11-Garnet
EMX must only have one drawing per mold.  How would you handle the situation where you have multiple drawing files referring to the same model?  If you are in a PDM environment, then you can open the related Drawings from the PDM.
bduncan
It's a product of B&W http://www.buw-soft.de/ And you can down load from here https://www.ptc.com/appserver/auth/it/esd/index.jsp IF you bought the license from PTC.
PTCModerator
Emeritus
MarianaSousa
You always have the option to do a mapkey to do that.
1. AA.asm
  1.1 BB.prt
  1.2 CC.asm (mapkey to make a drawing of this subassembly)
szycha63
8-Gravel
We are in 2020 as you know
Why do I have to create mapkey its time for PTC to develop BASIC and most
used commands
Solidworks have this option since 1997
Any questions?
Mfridman
Status changed to: Under Consideration
S_Edgenear
Why is the voting blocked in this specific idea?
BenLoosli
23-Emerald I
There are a number of reasons an idea has its votes blocked.
1) age of the post and limited responses
2) PTC has acknowledged this and maybe working on a solution
StephenW
23-Emerald II
There are several requests for this. This one is listed as under consideration
https://community.ptc.com/t5/Creo-Parametric-Ideas/Right-click-open-drawing/idi-p/458132
olivierlp
Community Manager
As per @StephenW's note, I merged an older ideas that was not archived into this newer one - also not archived, keeping the status of "Under Consideration" initially given by @Mfridman and merging the votes. The comments are clearly from 2 different times, but at least, the 2 ideas are consolidated.
@S_Edgenear I am not sure why the votes were frozen here. Apologies for the inconvenience. I am reopening them.
S_Edgenear
If PTC adds the possibility to have a one to one or a one to many association between parts and drawings, or assemblies and drawings, one could extend the possibility to rename the parts or assemblies, updating the references to the new part names or assemblies in drawings. Not all people use PDM, and it is a very slow and error prone when trying to rename a part or an assembly for which drawings have allready been mande. A quick button to quickle open the associated drawings to a part or an assembly would solve one problem, but if we need to open the drawings only to be able to rename the parts or the assemblies, this process could be automated too, so that the drawings do not loose references to the renamed parts or renamed assemblies.
StephenW
23-Emerald II
@olivierlp
That status is not set to "under consideration" as expected.
olivierlp
Community Manager
@StephenW   My bad! Thanks for catching this.
szycha63
8-Gravel
its about time
solidworks have this ability since 2007
szycha63
8-Gravel
just going further
open drawing of every part from assembly tree of any part just right click and pull down menu
maybe I'm asking for too much from PTC programmers
