Open a file "As stored" directly inside Creo
Dear PTC Team / Community,
We wish to suggest a modification concerning the system behaviour when opening files directly inside Creo (Menu -> File -> Open).
Today, using this method, the file will always open "as latest" (please see the sketch attached below).
We would like to have an option to open the file "as stored" directly inside Creo (Menu -> File -> Open).
If you have any questions, please let us know.
Best Regards,
ThyssenKrupp Fördertechnik Latino Americana Team
Bruno Castro (bruno.castro@tkfla.com.br) and Dr. Obretinow (roland.obretinow@tkfla.com.br)
3 Comments
rsobecki
I suggest if the status will be different during openning as it was as stored then Creo should ask user if he wish to open the drawing "as stored" - old version in general and maybe in the fly show the defferences
HerwigSchwarz
11-Garnet
This depends on the current Workspace setting.
Default behaviour is as follows:
  • If the object you're about to open is the latest one, then Latest configuration is used
  • If the object you're about to open is not the latest one, then As-Stored configuration is used
You can change this by editing the preferences of the active workspace.
olivierlp
Community Manager
Status changed to: Archived
