The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Open *.sdexp files in Creo Parametric
As per articles:
  • CS274910
  • CS30578
  • CS159848
There is no way to open *.sdexp files in Creo Parametric, ideally, we would like to convert a library of *.sdexp files into a format that Creo Parametric can read. This would be required so that companies can migrate from Creo Elements/Direct to Creo Parametric and still be able to use the legacy files without having to manually open every single file in Elements/Direct and then saving as a *.pkg or another format that  Parametric can open or import.
