Creo Parametric 4.0 is able to open native Solidworks files. Sometimes Creo fails and Displays the message "Error Model name '....SLDPRT' contains unsupported characters. ... cannot be retrieved". See also CS233522.
The implementation should be improved. Any character that is valid in SolidWorks should be supported.
