Optimization design constraint can be driven through a parameter
Actually you have to put a value or you can use an alternative technique by creating a relation analysis with the result is the goal for the feasability....
Use a parameter directly for a soft parametric, isn't it a good idea?
1 Comment
olivierlp
Community Manager
Status changed to: Archived
