We need a new config.pro option for an automatic regeneration of the children in topological failures.
Benefits: no resolve mode + no blocking in case of failures + No disappearance of topological children.
Possible name for this option: regen_failure_handling “medium_resolve_mode”
With Creo Elements/Pro 5.0, PTC introduced a new type of Reference -> “Topology System References”.
-> A hole intersecting another hole will be referenced as a « System » Reference Type.
In case of failure, the Topology System Referenced children fail also !
Note: In this example, if the failed feature is suppressed, all the 259 topological children will re-appear ...
