Option to avoid log files when exporting step files (__out.log.1)
It would be useful to have an option to avoid log files when exporting STEP.
intf_generate_log_file no    this option doesn’t work for export
9 Comments
scott_rockwell
Agreed, STEP files, IGES, STL ETC.
A simple check box in the save as dialog would work also.
RaphMORIN
Just discovered there's an option for this now ! See below :
Chris3
20-Turquoise
To clarify, this is a new option in Creo 4 starting with F000
Toby Metcalf‌  you can mark this idea as implemented.
Tmetcalf
Emeritus
Thank you Chris - I have updated this idea.
Best,
Toby
NicolasBourgeoi1
Hi CHRISTOPHER REES & Raphaël MORIN & Toby Metcalf,
It doesn't seem to work ...
Did you try to export a DXF from a drawing ?
RaphMORIN
I think in this case, it's the option below :
Chris3
20-Turquoise
As the config name inplies
intf3d_out_create_export_log
only applies to 3D models not drawings.
NicolasBourgeoi1
Thanks for intf3d_out_create_export_log  option in Creo 4.0.
I opened a new idea (8992) to avoid log files when exporting 2D drawings in DWG and DXF.
Best regards
Nicolas
Option to avoid log files when exporting DXF & DWG files (__out.log.1)
PTCModerator
Emeritus
