A way to either automatically optimize region order (similar to drilling) in Volume Milling or by pick order (similar to the old style). It is time consuming to order a large amount of regions using the current method of ordering them.
It's hard to see but there is an excessive amount of rapiding in the default zig-zag order creation. This amount of regions takes a very long time to order using the current method.
