In the drw if you "show" a feature's dimension and make it "ordinate", this behaviour is reflected also in the 3D model related; so if you are in 3D and goes to edit the same dimension, it will appear as ordinate as in the drw.
What I ask for is the scission of this behaviour between the two environments.
Bye
