The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Orient View Normal to Axis
The orient View option includes two axis options to orient vertical and horizontal.  The option to view Normal to axis needs added.  Reason: Verify hole alignment visually when working with brackets mounted to surfaces is one example.
The image below is from Wf5.  I have confirmed with PTC technical support that the function is not available in Creo Parametric 2.0 using case 10799554.
4 Comments
lbai
This functionality is enhanced in Creo 3.0 referring to http://communities.ptc.com/ideas/1096
dbreda
1-Newbie
This functionality is enhanced in Creo 3.0:
View > Saved Orientations > View Normal or from the Saved Orientations dropdown in the In Graphics Toolbar (IGT)
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
