I'd like to be able to output multiple operations in Creo/NC, rather than the current way of single operation output selection. I believe it would save a ton of time for users that wish to output all the operations in a project, because they would not have to be at the machine upon the completion of each output in order to start the next output.
Here is what I'd like to see:
1.) Select "save a cl file"
2.) Select "operation"
3.) at the point that all available operations are shown to select from, wouldn't it make sense to be able to "select all" operations for output?
4.) Then I can walk away, go for an office mail run, lunch or etc.
5.) Get back to the computer, and post all the cl files that were output when I was on the other tasks.
Thank you!
