PDF U3D (3D PDF Export) - Add quality setting to export options
At the moment there is no way to control the quality of the PDF U3D (3D PDF Export) from Creo directly in the Options dialog. Sometimes this leads to missing elements.
A PTC call revealed that the config option "shade_quality" also affects the quality of the PDF U3D Export. In our case changing it from 3 to 5 resolved the issue. However this is not at all an intuitive way of taking care of the problem. Therefore I propose to add a quality setting or slider to the Options dialog.
