I would like the PSF file location to be variable and set from the config.pro or sup.
Reasons
The config.pro already does this and it is very useful so this is not a new concept.
At my company increased access control is making it more difficult to update individual users.
The individual users do not have the ability to change the PSF file since it is in the programfiles area.
If the PSF file could be located somewhere else that does not have file restrictions no admin would be required.
PTC changes license names so the pdf files need to be updated.
My company changes license servers due to maintenance or sudden failure.
Right now if an emergency happened we would have a delayed response due to the access problems.
I know there are other ways to solve this problem but the less work arounds the better for all.
