Creo- Mechanism needs to have the feasibility to do dynamics study for Chain.
1. Mechanism should be real case.
1. Assembly constraint between Bush and Pin should be as it is real scenario (i.e.: Pin should have 2 linear DOF and 1 rotation DOF) within the boundary(bush hole).
2. Chain should travel with respect to 3D contact only. Not in the defined curve path.
