Parameter - adjust the width of the first column
hello
Have the ability to adjust the width of the first column with a default value
5 Comments
Sapphire I
This is a regression in functionality as Wildfire used to allow the first column to be changed in width. We had a mapkey that would change all column widths in WF, but had to redo it in Creo since the first column cannot be set by a number.
You can change the first column width by dragging with the mouse.
Hello
I try with an older version, and if it's a regression, I'll open a case
Have a nice day.
impossible in WF4
Emerald I
You couldn't do this in Wildfire 5 either.  (At least not in M250.)
What you CAN do is save your preferred configuration and then load it with the config.pro option parameter_dialog_setup_file.
