Background details:
1. working in the Vehicle industry, I'm a CAD Admin, stakeholders: our mechanical designers.
2. Working with Creo 8.0.1.0
Problem Description:
3. In PIN connection in an assembly ("ASSY1", as an example), It is not possible to use 'enable regeneration value' as a parameter, so when assembling this ASSY1 assembly as flexible/var item - I will be able to decide whether this parameter is enabled or not.
Furthermore, it would be fantastic if all other fields will also be parameterized externally - to be used when this kind of assembly is assembled as flexible/var item.
5. Solving this issue will be very beneficial and help us avoid duplicating same assemblies over and over again with different rotation axis properties for each occurrence in a top-level assembly.
Best Regards to all!
