DESCRIPTION:
Using the mini-toolbar select from parent list and selecting the parent, the parent model name should appear in the message area. When you select a part in the graphics window, the selected model name appears in the message area. But when selecting the parent from the list, the parent does not show up in the message area even though the parent is selected in the model tree.
Related config option that supposedly turns on the message log selection, but it does not work when parents are selected
provide_pick_message_always yes
JUSTIFICATION:
