Pass Parameter Value to Mfg Operation Comment Section
Request the ability to pass parameter values to the Manufacturing Operation Comment Section.  This would allow viewing of those values in the NCL / Post Processor file.
I realize that parameter values can be passed through Sequence and Auxilliary sequence CL Commands.  It would be advantageous for our business processes to be able to display specific paramter values by operation rather than sequence.
Kevin Keizer
Steelcase, Inc
7 Comments
ptc-823356
PTC Case C10792772
mritz
2-Guest
This would be a powerful tool allowing conditional changes to the comments for operators.
ptc-1705126
1-Newbie
This would be helpful. Long over due.
Hr.Tox
6-Contributor
Hello PTC,
any news here?
To my mind absolutely necessary to use synthax &parameter in MFG comments.
Please fix this.
jbaur
11-Garnet
Can we get an answer from PTC directly?
ptc-823356
I checked and Case 10792772 posing this question is listed as CLOSED.  This is the last entry regarding the Case.
Subject: C10792772 [ ref:_00DA0YLPa._500F0ACbxe:ref ]
Hi
Kevin,
This is in reference to case C10792772 with the description
"Operations Comments section; Is there a way to pass parameter values to the
Operation Comments section? If not, consider this an enhancement
request".
I have taken ownership of the above case. I believe it's not
specific to some parameters. You may need all the parameters.
Let me
check this and i will get back to you.
Nihar
PTCModerator
Emeritus
Status changed to: Archived
