There should be access to the actual count of a patterns
. I deal mostly with hole patterns so my references will directed towards holes, but should be carried out for all patterns.
EX. You pattern a hole but suppress some of them. The correct count can be found in a hole note if its a standard hole. Since this is already being created the user should be able to access it.
As mentioned, the above only works for standard holes and you have to have the hole note set to show the pattern count.
