Pattern Sketch items
0 Kudos
Let's get some useful functions into the sketch mode and add an ability to pattern sketch items!
5 Comments
Regular Member
There is an ability to pattern "sketches" already.
Personally, however, I never use that functionality. I would much rather use the patterning in 3D than on 2D since 2D is temporary (just as long as the workplane stays around), while the 3D patterns stay with the part.
Visitor
Peter, I am in CREO 3 modeling, the sketch function.  Not sure what menu structure you are picturing?
Aquamarine
Tom you posted this in the wrong area.  It should be under Creo Parametric.
Visitor
Moved
Topaz II
Tom Davidson
You may want to vote on your own idea....
