Pattern - turn axis on
When in the pattern feature, the default is dimension. If the drop down menu is set to axis, automatically turn the axis display on if it isn't already since you need to choose an axis.
3 Comments
Alexandrite
You can pick an axis from the feature tree. This would cause a huge performance hit in large assemblies where there are lots of axes.
Topaz II
I am not positive on this, but only on defined axis, not axis that are made with revolves, .... they are not typically in the tree.
Community Manager
Status changed to: Archived
