Allow redefinition of the type of a pattterned hole without having to delete the pattern first. It is handy to copy a part and modify the copy to make a mating part, but not so much if one has to delete a hole pattern to redefine from a tapped hole to a simple (clearance) hole, then remake the pattern. This is especially frustrating when the pattern has to be irregular to avoid breaking thru other features.
