Piping: add a choice for line color.
In piping since Wildfire 4.0 you can show thickness line before creating a solid part from your centerline.
I think its a great unhancement but PTC missed something very friendly: the choice of the color.
After several minutes in order to understand who the default color was apply I finally fund that the curves color is apply by defaut at the pipe visualisation...
After that it's impossible to change the color of the line.
So the tips is that you have to change the curve color in Preferencies before creating the Assembly of your pipe...
I think PTC need to allow a color selection at every time for these visualisation and allow to change it.
If you works on a simple pipe that ok but if you route more than 20/50/100 pipes on a machine or a vehicule it's not so friendly with all the same color.
Hydraulic designer like to apply a color for a fonction or for a Pressure value/level ....Red/ Bleu /Yellow/Green ....
1 Comment
Community Manager
Status changed to: Archived
