Please bring the old sweep (closed trajectory, open section -> add inner face) back
In pre-Creo releases there was the fantastic option to create a regular sweep using a closed trajectory and an open section.
The system then presented the option "Add inner face" to create a solid this way.
This was a very convenient feature.
It is very sad that this feature is deliberately omitted in the Creo versions.
Modernizing the GUI should not lead to a GUI for dummies or to lesser functionality.
Best regards,
    John Bijnens
8 Comments
gvora
6-Contributor
PLEASE REFERE TO MY CASE # 10702268 & 10703810 AND RESPECTIVE SPR # 2119554
ON 02/28/2012.
I AM REGULARLY ASKING PTC AND I AM NOT GETTING ANY ANSWER.
TimMcLellan
6-Contributor
Removing Functionality, not a good idea.  I was working in Creo 2 and wanted to use this functionality only to find out it was eliminated.  Now, more steps (use FILL), more features and less usability.
PTC this feature should be brought back.
Also, I am now going to create a UDF from WF5 that contains this functionality so I have it available in Creo 2+..
jganter
6-Contributor
Also opened a Call C11664829, where our users want to have this functionality (WF4). After several mails the calls was closed and our users are not really satisfied.
JB_87049
I had the same experience. I was told that this functionality wouldn't come back but it was not so stable as I thought.
Hm. It was stable enough to stay in so many releases ?
AndyHermanson
This is what we did. User created a udf to just drop in.
rwirrer
3-Visitor
It's possible to switch to legacy mode and there you will find the old sweeptool...
With the old one it's possible...adding a mapkey which navigates to the tool should work...
Just an idea.
PTCModerator
Emeritus
gvora
6-Contributor
Please bring the old sweep (closed trajectory, open section -> add inner face) back. It is high time this feature/option must be brought back. It is highly useful.
There must be no more delay to bring it back.
Thanks.
Gautam  Vora.
