We use ProSectionLocationGet and ProSectionEntityGet to get a position of an extrude.
The problem is that if the extrude is a member of the pattern, these API doesn't give us right location depending on patterns. (We get right information for some patterns.)
We created a call C10910807 and were told that it was a design of ProSectionLocationGet and there was no API currently available that would provide the transformation between pattern members or between pattern leader and a pattern member.
Would you enhance toolkit to add an API to give us the transformation so that we can get the position of patterned extrude constantly please?
