Currently the file sizes generated when exporting a .PVZ from from Creo Parametric are much larger than can be generated using eDrawings. Quite often the file size in eDrawings is 10% of what can be achived when exporting from Creo Parametric with Out Of the Box settings. PTC can you please review this particular functionality to see if there are any ways to reduce the file size from within Creo Parametric itself. We have found that by editing the recipe files, the line for "adapter/dglTolPerc=0.2" compared well to eDrawings in file sizes, but this is too much effort for most users. Can we have a config.pro setting that make this easier? In eDrawings they have a slider bar which can be easily changed.
