Position-relative snap to centers
At this moment the 3D Co-pilot cannot snap to centers of elements during a relative position action.
This would be an exelent feature, for 18.x & 19.x
(used to work in 17.x and below)
5 Comments
rschmidt
3-Visitor
Very good Idea
PeterKehoe
Note that you can do this if you use the "2 Points" option for positioning instead of the "Dynamic" option. Hold down the SHIFT and CTRL keys when selecting an edge to catch to the center of that edge.move_2_pts.bmp
thollerweger
7-Bedrock
Hello Peter,
your suggestion is good if you want to lay the starting point exactly over the target point.
Bit if you want to mov in a specified direction and only the distance in this direction should be used, the idea from F.A.N. van den Berg would be very good.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
