Possibility to add only nut(s) and/or ring(s) in Intelligent Fastener tool (IFX)
Sometimes you only want to assemble nut(s) and/or ring(s), without a screw/bolt (e.g. on threaded rods or threaded studs). Now this is only possible with IFX by a workaround (placing them with a bolt and then remove the bolt afterwards).
1 Comment
OliverGräbner
