Possibility to modify tolérance dimension on a inhéritance feature
hello,
in some case, when we use Cetol from Sigmetrix for make an analysis of variation on our part; we must drive the tolérance of dimension from inhéritance feature
In this case, the control panel of the dimension disable the tolérance.
It's a problem because we can't use this dimension in Cetol.
Nevertheless, this dimension can be modify when we use the variant tool in inhéritance feature. (but Cetol can't use this variation...)
It would be pratical to enable this tolerance in the control pannel of dimension.
We have the same problem with geomtol issu of inhéritance feature
1 Comment
PTCModerator
Emeritus
