Post Process symmetric extrapolation results in CREO Simulate
If you cut your model to use symmetry in CREO Simulate, also in the result windows you will see half model. It would be nice if the software "mirror" the sesults to display the full model within the result windows. A similar behaviour is implemented, with a different aim, in the "Visual Mirror" command, located within the "In Graphic"  toolbar, when you create or edit a style feature.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
