Now is possible to use any general scale of the drawing module in Creo Parametric and people have to write it manually. There is two bad moments:
1. User have to remember all right scales;
2. User can mistake - use wrong scale (1:3 for example).
It will be great to have drop-down list (restricted vals) for fast and easy use right scale. Of course possibility to use any value of scale must to exist also.
Let's make software conviniently and easy to use together.
