Prevent Snapshot Constraints from Supressing when a Assembly with a (6DOF) Mechanism Joint has been Rotated or Reassembled
Please fix Creo Parametric so when a sub assembly with a mechanism joint like 6DOF reassembled to the assembly 90 degrees to it original orientation (never removed from the assembly) the snapshots with motion axis constraints do not go to a suppressed state.
Currently to fix this you have to delete each motion axis constraint and re-add it to the snapshot and reassign the values to it.
Huge waste of time.
Don Anderson
1 Comment
olivierlp
Community Manager
Status changed to: Archived
