Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I think you may not understand what I am asking for. Sketch centerlines are infinite.
Sometimes I have line entitles that are coincident with sketcher centerlines. If I want to make a line entity that is coincident with a sketcher centerline equal to another line entity Creo shouldn't highlight an infinite sketcher centerline that can never be equal to anything.
