The Text to Geom command is useful for imprinting text on faces of a part. But the user interface for this command is cumbersome. It would be helpful to have this improved so that there was some on-screen preview and editing capability. As a first step, it would be helpful to have a Preview button in the dialog so that a user can see what the text will look like on the workplane, and then have the ability to edit it, before pressing the OK button. That would be the minimum additional functionality. But further enhancements could be to be able to dynamically drag the position of the text, dynamically scale the size of the text, and to be able to change the "adjust point" for the text.
