Print from Information Window
To be able to print from Information Window would be nice.
4 Comments
StephenW
23-Emerald II
I agree with the idea. Just as a side note, it creates a text file, in your case named modmass.dat in your creo working directory.
SkyKing‌, you should vote on your own idea.
STEVEG
You would think there should be a Print option.  So much for PTC being consistent.
But you can also use the select-all in the window and copy then paste it in Notepad, Wordpad or Word.
SkyKing
7-Bedrock
Also on the side note, there is a “Print” option in “Mass Properties Report” that does nothing.
olivierlp
Community Manager
Status changed to: Archived
