Right now, when creating a cabling spool, they are all identified in the model tree using its modelitem feature ID. This is a pain because it requires users to go into the spool manager just to find out information about the spool itself (aka, the name). Shouldn't the model tree show the Spool's name as the primary content?
Right now there IS a method of visualizing that information, but it requires adding another column for "Cabling Info->Designation". I think that it shouldn't require an extra column, it should be automatically set as the name of the feature in the model tree. (especially considering you already cannot have two spools with the same name).
At the bare minimum, there should be a config option to allow users the option to show "spool_name_in_model_tree".
