per call C11250411
Short Description | How to set option 'Holes > Depth > Measure > By Tip' to come up as the default option for holemaking sequences? |
Symptoms | Users seems to be forgetting to reset 'By sholder'/'By Tip' option , burried 4 levels deep in the dialog boxes which causes metal scrap... |
Steps to Reproduce | Just follow the intended work flow and make 100+ holes...Please do not suggest to create XML templates and use them. We know about this option. |
Error Messages / Warnings | |
Reason for Closure | Solution Delivered |
Closure Details | Informed the customer that it is not currently possible to have the default option set to "By Tip". |
