Security Alert Log4j Security Vulnerability. Click here to know more.
Pro/TOOLKIT function for changing the Layer Id
Pro/TOOLKIT does not provide a method to change the Layer Id of a layer, while the GUI dialog "Layer Properties" allows to change it manually. A method for changing it from (synchronous and asynchronous) ProTK-App without using mapkeys is needed. (See PTC Support Case Tracker ID 10896823).
3 Comments
DomenicLaritz
As creator of this idea, you should vote for it too!
But you need not, if you don't like your idea.
HannesBuxbaum
3-Visitor
Of course! Thank you!
PTCModerator
Emeritus
Status changed to: Archived
