Pro/TOOLKIT function for changing the Layer Id
Pro/TOOLKIT does not provide a method to change the Layer Id of a layer, while the GUI dialog "Layer Properties" allows to change it manually. A method for changing it from (synchronous and asynchronous) ProTK-App without using mapkeys is needed. (See PTC Support Case Tracker ID 10896823).
3 Comments
DomenicLaritz
As creator of this idea, you should vote for it too!
But you need not, if you don't like your idea.
HannesBuxbaum
Of course! Thank you!
PTCModerator
Emeritus
Status changed to: Archived
