Pro/Toolkit - add notify event to capture layer status change
per call C11229318
Issue Information
Short Description Which ProNotify event has to be used to notify an application about layer status change in the active model?
Symptoms Cannot find any mentioning of layer related events in user guide
Steps to Reproduce -Change layer status
-trap it with an event???
Error Messages / Warnings
Reason for Closure Solution Delivered
Closure Details At present there is no Notification functions defined to capture the display status changes made to a layer in part or assembly. Advised the customer to try using ProCmdBracketFuncAdd () and add call back functions for involved commands in Creo Parametric 2.0
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
