Pro/Toolkit - missing functionality for ProNavigatorpaneBrowser... group of functions
per call C10681018
Issue Information
Short Description How to set a focus to a navigator pane tab added with ProNavigatorpaneBrowserAdd
Symptoms The tab added to a navigator pane via Pro/Toolkit could only receive a focus through user interaction
Steps to Reproduce Use a function ProNavigatorpaneBrowserAdd ...
(Please answer via email, most likely it is a gap in functionality, I want to be sure before filling up an enhancement request)
Thanks.
Error Messages / Warnings
Reason for Closure Solution Delivered
Closure Details As per Pro/Toolkit for Creo Elements/Pro 5.0 product specifications, this functionality is not yet available. There is no API currently available to set the focus on the navigator pane that was added using ProNavigatorpaneBrowserAdd().
Also is missing - the ability to remove  ProNavigatorpaneBrowser tab when the browser is no longer needed...
2 Comments
sully7
Years later... still no added support. I'd like to at least see ProNavigatorpaneBrowserRemove added if possible.
PTCModerator
Emeritus
Status changed to: Archived
