Pro/Toolkit - missing functionality to access user locked parameter status
per call C10664404
Issue Information
Short Description Customer would like to know how to determine if a user-defined parameter was locked by the user.
Symptoms seems to be missing functionality
Steps to Reproduce Try to call
ProParameterRangeGet( ¶m, &if_locked, NULL, NULL);
or
ProParameterIsEnumerated( ¶m, &if_locked, NULL);
if_locked would be PRO_B_FALSE and return status of both functions was PRO_TK_NO_ERROR
Calling
ProParameterDriverGet( ¶m, &drv);
drv was set to NONE by the function and return status was PRO_TK_NO_ERROR
In all cases the value of parameter was an integer type...
The only meaningfull return status was from ProParameterValueSet which was PRO_TK_GENERAL_ERROR but this approach does not look like a good one.
Error Messages / Warnings
Reason for Closure Currently not supported
Closure Details Informed the customer that currently no APIs available to determine if a user-defined parameter was locked.
2 Comments
FV
had been implemented in Creo 3.0
PTCModerator
Emeritus
Status changed to: Archived
