Pro/Toolkit - need a function to query model - drawing dependencies
per call C11343615 - tech support suggested to fill up a 'product idea'
Issue Information
Short Description Is there a way to access information about ProSolid and ProDrawing models referencing ProSolid model while the later been renamed in session without scanning all models at known locations ( current directory, search path ...)
Symptoms Try to rename a part model while referencing drawing is not in session and try to retrieve a drawing afterwards...
Steps to Reproduce Rename a part model while referencing drawing is not in session and try to retrieve a drawing afterwards...
While this is an age old problem, I was wondering if it possible to use one of ProNotify types to capture the event of adding solid model to a drawing? Or is it advisable to use a bracket function?
Thanks in advance.
Please email me an answer if any. Do not call please.
Feliks.
Error Messages / Warnings
Reason for Closure Currently not supported
Closure Details At present there is no Creo Toolkit API available that could give the drawing names in which a given model is used. Advised the customer to submit a product Idea
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
