Pro/Toolkit: please restore functionality of pro_compute_volume function
Per call C10952765 : Cannot find volume of the solid volume due to removal pro_compute_volume() function...
PTC tech support reply:
First of all, I apologize for the time taken.
The only way I see which may help us in this case is, build the application after including the prodevelop includes and libraries from Creo Elements/Pro 5.0. Please ignore if you are already aware of this.
I suggest you to submit an Product Idea requesting equivalent function(mentioning the use case) in order to evaluate this functionality for future releases by PTC product management.
https://www.ptc.com/appserver/cs/misc/PTC_Product_Ideas.jsp
5 Comments
Moonstone
In which release did PTC remove this function?
Also, isn't there an equivalent function in the Object Toolkit?
Peridot
Hello all,
Pro/Develop was retired sometime in Creo, pro_compute_volume is in prodevelop library.
The function was replaced with ProFitInterferencevolumeCompute. Unfortunatelly the replacement function works with interference volumes only while pro_compute_volume would work with any closed quilt. There is no function ( to my knowledge) in Pro/Toolkit or Object Toolkit to calculate the volume of a closed quilt.
Thanks.
Feliks.
Gravel
Would ProQuiltVolumeEval work for you Feliks?
Peridot
Hi all,
Patrick, the function ProQuiltVolumeEval was added to Pro/Toolkit sometime ago. It had solved the API gap.
Feliks.
Community Manager
Status changed to: Archived
