The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
ProModelitemByNameInit API should return modelitem for feature created with default name
Reference : PTC Case C13465057
I had opened a support case with this ID & received the following reply,
In the model database, the feature is not recognized using default name.
A feature can be initialized only by using the name explicitly assigned by the user.
Only for Datums (planes, axis, CSYS), Creo explicitly assigns a permanent name,
that can be initialized using its default name by using ProModelitemByNameInit().
So your issue is work-specification, need to change the feature name.
At present, this API returns PRO_TK_E_NOT_FOUND error for features created using default name.
We cannot ask all our customers to edit each creo model & rename every such feature.
Therefore, requesting you to consider this as an Enhancement Request.
Thanks in advance.
PS: Please keep 'nikhil.ruikar@vaal-triangle.com' in email CC.
Feel free to call me between 10AM-7PM IST. (Mon-Fri)
Nikhil Ruikar
+91 9595875722
Skype: nikhil.ruikar.sigmatek
1 Comment
olivierlp
Community Manager
Status changed to: Archived
