Probe Selection - Objects Tab as default
When you select an object with "Probe Selection" (CTRL-Tab-Key) currently it opens by default the elements tab.
For my use case it would be better if the probe tool opens by default the "Objects" tab and expands the first node where you can select the owner assemblies.
1 Comment
PTCModerator
Community Manager
Status changed to: Archived
