While in Sketcher, when selecting curves or edges of type 'loop' from a surface to project onto the sketching plane, 'SEL CHAIN' must be stepped through for each chain and individually 'Accepted'. For complex surfaces with many features, this can be confusing and time-consuming. To the 'Type' menu 'Select Use Edge', add a menu item for 'All' that will pre-select and highlight all the curves and edges , and then allow the ability to easily select or de-select from the highlighted features
