Provide Documentation of System Color Names and Uses
The system colors, for example system_geometry_color, can be set via specifications in a file. For example, I use "syscol.scl". To the best of my knowledge, there is no documentation of what parameter names are available for these settings. Equally important, it is not clear what effect setting any of these parameters will have.
Therefore, I am requesting that there be thorough documentation provided, in the Help files, of the following:
(1) Parameter names
(2) Screen elements affected by a given parameter
(3) Syntax for the settings file, i.e. what alias_sec_dim_strong_color_to means, the color value ranges, etc.
2 Comments
BenLoosli
23-Emerald II
There used to be some information in the Fundamentals guide in the WF4 Help Topic collection.
File is too big to attach, send me an email to: looslib<at>centrusenergy.com and I will send you a copy.
olivierlp
Community Manager
Status changed to: Archived
