Provide an API to update position of datum feature
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Creo Parametric are you currently running?
Creo 5,Creo7 and Creo 8
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We are trying to update position of datum feature using toolkit API but there is no API for that as it is possible in UI
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @supriyar for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
Here are a few examples of well documented ideas:
Option to Import STEP file as Inseparable Assembly... - PTC Community
Make Shrinkwrap quality more scalable to data size... - PTC Community
Improve/fix the sheetmetal mirror feature - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
supriyar
9-Granite
Thank you @olivierlp  for the suggestions.
Please check it and let me know.
All the industries that develop CAD plugins and use plugins.
We are trying to update the position of the datum feature using toolkit API but there is no API for that as it is possible in UI.
Here, the datum feature tag is not visible properly as shown in snaps.
It's possible to update the position of that datum feature tag in UI just by dragging it but I want to change its position by using APIs only.
But I did not find any API which will update the position of that datum feature symbol.
it'll become visible properly instead of doing it in UI.
More robust mirror functionality will save time and money
olivierlp
Community Manager
Thank you @supriyar for your additional info. Based on what you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
