Provide feedback on model when using 2D CoPilot
When using the commands which use the 2D CoPilot and catching points on a 3D model, the edges and vertices on the model are projected as temporary construction geometry on the active workplane. But if the workplane is off of the part, it is not obvious if you are selecting the right edge or vertex.
But with the old, "classic" commands there was feedback on the model, so there was no question.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
